Hi to everyone, I have nicely working AVANT 32 DVD , everything works great with this TV, really enjoying it , but somehow now DVD player stop to work. And its pitty, because its nicer than some pseudo " home cinema " systems ...
If I give some DVD or CD ( doesn´t metter original or copy..) inside, doors close and nothing happend, no sounds from mechanics, on screen only written BLOCKED and thats all.
Does anyone have a similar experience ? How is possible fix it ?
Thx a lot for all kind of reactions.. :-)
Hello Jura and welcome to Beoworld.
Your DVD unit may need replacement but there are a lot of possibilities to be explored first.
Because of the age of the TV you will find most threads about similar problems in the archived forum ( top right tab). Search on Avant DVD. You will also see a lot of related threads in the non- english forums but you can probably use Google chrome/ translate.
Graham
