HI Everyone,
I had my Beolab 5000 and 4500 Speakers connected to a Beovision AV9000 and Beocenter 9000.All working perfectly with surround and all.. So of course I had to mess it up..
I sold my AV9000 TV since we don't want a TV anymore in the bedroom where we had it..
Suddenly I realize there are no beolink speaker connectors on the Beocenter 9000 to use these together.(I know.. bad planning)
What do you recommend to make these 4 speakers work properly with the Beocenter 9000?
Peter
---------------------------------------------------------------------------------------------------------------------------------Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000, Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
..maybe just a Beolink Converter will do? and a splitter cable (powerlink) to the speakers?
Hi Peter,
No problem! You can connect two of these speakers to the Beocenter "Speaker 1" sockets with a set of Speakerlink cables to get sound and the displays working on the speakers (please set the speakers to "Audio" using the slide switch on the side):-
http://soundsheavenly.com/speakerlink-4-pin-din-cables/19-speakerlink-compatible-4-pin-din-cables-for-older-bo-speakers-sold-as-a-pair.html
If you need to get two sets of speakers with displays working together, please drop me a line via my sponsor link at the foot of the page and I will be pleased to help with a custom cable to make this possible!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
