LC2 turns off light by it self
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Thu, Oct 27 2016 5:06 PM
Hi... One of my LC2's in my livingroom, has begun jo just turn off the light by itself.
It suddenly dims the light(like pressing light+stop), and then it can be turned on again(light+light). After some time, it dims again, and this can be repeated some times.
After x times, it will not turn on again, until it has been off for a while.
Is there a protection circuit that turns off if it gets to hot, or is this perhaps just a bad solder somewhere ?
/Weebyx
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Oct 28 2016 9:33 AM
there is indeed a thermal protection in the LC2.
So i guess tere might be thermal problem with the dimmer.
It's a NTC with 100K which should be mounted in such a way that it has thermal contact to the cooling plate / heatsink .
Ralph-Marcus
Page 1 of 1 (2 items) | RSS
