Beosound 300 - Clamper issue
shalom555
Posts 15
shalom555 Posted: Tue, Nov 1 2016 8:35 AM
I recently bought a Beosound 3000. The problem is that when I press "LOAD" on the unit, the clamper does not move. So I end up powering off the unit, physically move the clamper to insert the cd , power on the unit and then pressing Cd on my BEO 4 to play the cd! I am able to forward and rewind the cd tracks by using the Beo 4 . Oh the radio works fine.
Any help or suggestion to rectify this problem is appreciated.
Many thanks
Christian
BeoChecker
Switzerland
Posts 148
Do you hear the noise of a Motor inside the beosound if you press the load button?
If it is so, the drive belt of the clamper is worn out or torn
BeoChecker
shalom555
Posts 15
shalom555 replied on Tue, Nov 1 2016 10:45 PM
Hi appreciate your advice. How I change the belt ?
Many thanks again.
Christian
BeoChecker
Switzerland
Posts 148
Remove all screws on the back and remove the back cover. The clamper mechanism is located behind the CD. To change the belt you have to remove and disassemble the clamper mechanism.
Good lock!
BeoChecker
shalom555
Posts 15
shalom555 replied on Wed, Nov 2 2016 11:55 PM
Yes thanks for your advice n encouragement. I will do it this week end . Btw I managed to find the service manual which is very helpful . You have a blessed weekend .
Christian
BeoChecker
Switzerland
Posts 148
Position 9104 is the belt for the clamper
Position 9123 is the belt for the glass doors
BeoChecker
shalom555
Posts 15
I have opened up the rear of the Beosound 3000 . The rubber belt is still there.
I will get a replacement belt from the electronics shop n change it next week .
Also LOAD, CD on the unit is not working!
Many thanks again for your advice n help.
Christian
shalom555
Posts 15
More pictures !
BeoChecker
Switzerland
Posts 148
Does the motor work if you press the LOAD Button?
If not it is usually a defective PCB9 (light and motor control print)
BeoChecker
Page 1 of 1 (9 items) | RSS
