Change Receiver Avant 75 to NG
This post has 11 Replies | 3 Followers
f5434964
Austria
Posts 206
f5434964 Posted: Tue, Nov 1 2016 12:31 PM
Dear friends of Beoworld!
as the new price table lists the Avant NG with DVB T2/C/S2 HEVC has anyone thought about the possibility of changeing the reveiver of an old Avant to this new option?
would this be possible?
best regards
elmar
Millemissen
Flensborg, Denmark
Posts 14,680
There is no seperate receiver/BeoSystem with those specs.
Besides, the system in the Avant is a built-in one.
There are other differences Avant/Avant NG than merely the system - bluetooth antenna etc etc.
f5434964
Austria
Posts 206
What a pitty ...
f5434964
Austria
Posts 206
I thought that The avant was made of lets say modules which could be exchanged oder necessary (eg broken); it would have been easy to replace any of them like the upgrade of a beo5 to a beo6 by replacing The screen...
Best regards Elmar
f5434964
Austria
Posts 206
Best regards Elmar
Roger
Norway
Posts 417
Roger replied on Wed, Nov 2 2016 11:41 AM
You can simply buy the Nvidia Shield and add it to the old Avant's as STB controlled by PUC - which is actually better as you not only get 4k with YouTube, but also Netflix (removed from the last SW update of the 14/Horizon/Avant NG) in 4k.
Roger
f5434964
Austria
Posts 206
Looks good; if it had a 4k blue ray Player would be a must have
best regards Elmar
Millemissen
Flensborg, Denmark
Posts 14,680
Roger:
Roger
Of course the Nvidia Shield is is an excellent device/possibility to have 4K content on the Avant, but it does not catapult it into an Avant NG.
There are many differences there - some for the better, some for the worse.
However, whether these (better) differences are worth it to change to a NG version, is highly debatable.
There are those, who think, that it would be better to stick with the current Avant ;-)
A pity though, that we will have to choose between a Nvidia Shild device and a 4K BluRay player with the current Avant ;-(
Roger
Norway
Posts 417
Roger replied on Thu, Nov 3 2016 9:36 AM
MM,
What is the differences between the Avant 75 and the Avant 75 NG?
Roger
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Roger,
well, I thought you were going to ask ;-)
There are several differences - a new and more powerfull engine, dual tuners with easy usb-recording, bluetooth instead of ir for remote controlling (easy update and syncronizing of the remote/the tv, support for Google Cast, updated HDMI-ports amongst the better.
A changed UI with focus on the AndroidTV platform and no easy access to connected (local and networked sources), no netradio built-in, no support for NL (as of today) amongst the worse (IMO).
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Nov 3 2016 12:31 PM
Millemissen:
Is that so? So you are not able to join NL sources from the Avant 75 NG (and vice versa)?
Millemissen
Flensborg, Denmark
Posts 14,680
@Hiort
First of all, there is no Avant NG yet.
But assuming, that the same sw version would be on it....if there were any, there would be no NL support.
However, I guess that this will be solved, before the Avant NG hits the shops.
M ;-) M
Page 1 of 1 (12 items) | RSS
