ethernet switch and picture quality
This post has 16 Replies | 1 Follower
olvisab
Posts 1,391
olvisab Posted: Sun, Nov 13 2016 11:20 PM
I have replaced recently a basic Netgear switch by a Netgear prosafe gs 724t.
The gain in picture quality is really important (details, depth, clarity of backgrounds).
Even my wife with her bad vision notices it.
It really worths to check this part of the a/v system.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Nov 14 2016 12:00 AM
That's really interesting! Do you think the new switch is allowing higher bandwidth, more bits per second, through? Did you ever do a speed test on it and the old switch? I do know that for many hubs/switches it's recommended to put lower bandwidth things on the downside of the hub/switch, and things like TVs and such that require more throughput upstream of it. At least that's the recommendation, I've not had to run a switch/hub at home yet, and the ones we used at work were all very high speed (and very pricey) professional ones.
Jeff
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Nov 14 2016 12:02 AM
To add, it sounds like whatever streaming you're doing is recognizing the difference and running at a higher bitrate setting. I've noticed that my downstairs TV when it first negotiates its connection via wireless at first the picture is almost SD but in a few seconds or so after it establishes the speed of the connection and adjusts and buffers it gets to full HD.
Enjoy the better picture!
Jeff
olvisab
Posts 1,391
olvisab replied on Tue, Nov 15 2016 12:36 PM
thanks jeff !
matbkk
Posts 43
matbkk replied on Tue, Nov 15 2016 1:11 PM
I am streaming most of my movies with Plex via Apple TV4.
Movies are stored on a computer inside my personnal network.
The Apple TV4 has only a 100mbps ethernet connexion but I have noticed a drastic change when I have changed my switch from 100mpbs to a 1000mpbs. No more buffering for HD Movies (up to 30GB per file).
My network is wired with Cat5e cables.
Mat
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Nov 15 2016 1:41 PM
Kind of makes you wonder how the 100mbs spec value was arrived at and how accurate it was on the old switch doesn't it? Kind of "on a good day, when the network gods are smiling, and there's no other issues, and no packet collisions, or EMF from a wall wire, we might get 100 mbs but only if only one thing is connected, and then it's "speeds up to." Whistle
Jeff
matbkk
Posts 43
matbkk replied on Tue, Nov 15 2016 2:13 PM
I agree 100mbps is theorical so let's sy that with a Gig switch you are maximizing your chances to get a decent speed.
L1NO
Posts 250
L1NO replied on Wed, Nov 16 2016 10:03 AM
Many switches that have 100mb/s port's don't have internal capacity do deliver 100mb/s on all ports. A 1000mb/s switch usually also up's the internal switching capacity. The internal switching capacity-spec can be found on better switches to buy the best in your setup.
kuyttendaele
Posts 707
Basically it comes down to the bandwidth your switch and network can handle.
The current BeoVisions have a 100Mbit port, 4K needs 30Mbit (give or take some Mbits... depending on the compression), so streaming from a 1000Mbit switch to your BV will not be a problem. If the stream is coming through a 100Mbit switch then buffering is possible and your stream can be downgraded if other devices are surfing/streaming/using the same switch.
Also... it's worth checking your Internet Provider's bandwith... If you have a 100Mbit Internet connection then you should be able to stream 4K from the Net; but that too can be compromised if other people are surfing/downloading/streaming over the same connection.
Concerning the cabling: Cat 5e cabling might do the trick (I'm not having issues); Cat6 will have no problems at all handling the 1Gbit connections;
For the record: Ultra HD Blu-ray has a bandwidth of 108Mbit so at this point the only way to have full 4K with all the whistles and bells is by a dedicated player over HDMI as the 100Mbit port on your BeoVision will lack capacity... but then again... it's around 66Gb per BD-disk if you want to rip them to a NAS... have no intention of doing that.
<audiophile modus on>
On a sidenote: also make sure that your RJ45 network connectors are premium gold-platinum plated, and keep your cables 5cm from the ground. I've noticed that the bits are more streamlined and the the picture is much sharper.. Sound too will be more fluid with a slight increase in the mids and highs especially around the 15.000Hz *
</audiophile modus off>
Karel.
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Nov 16 2016 10:34 AM
Have to say I noticed a difference switching from wireless on ATV3 to hard wired in that the picture appeared sharper and much quicker to load films etc- I've now hardwired both ATVs and my computer into the router and use apple remote on the second ATV connected to a DAC to stream music. Works really well.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Nov 16 2016 5:21 PM
I had one TV, a Samsung, on direct connection to the router, then moved it to wifi, and didn't notice a difference, except sometimes it takes a bit longer to buffer. But then, for wireless video I use a 5GHz network not 2.4 which should be faster. My home internet, when I test it which is often, reads 60Mbs download, about 5 MBs upload, which surprisingly is what they actually advertise and claim! I have never hard wired my big TV though, although I don't notice a degradation but it's hard to tell unless I compared. but the picture seems to depend more on the content, on the better streaming items it looks good enough I can't find fault with it, but that's just 1080p not 4K. It's not convenient or easy to hook my main TV in the living room to a wired internet connection, but it would make a very interesting experiment I think. Maybe someday if I get a long cable. I would be interested in seeing if there is any difference...hmmm.
Jeff
L1NO
Posts 250
L1NO replied on Wed, Nov 16 2016 5:40 PM
kuyttendaele:
Unless you use the RJ45 cable's for analgue signals (eg powerlink) it's virtually unpossible to have 'increased'  audio and video quality. Using any iso-standard cable will give maximum quality. Missing bit's (really bad cable) should give stutter if bit-correction in the receiving end did not fix this.
Duels
England
Posts 2,553
Duels replied on Wed, Nov 16 2016 5:41 PM
Jeff:
Well it had to happen to someone one day!
henrik
Sweden
Posts 458
henrik replied on Wed, Nov 16 2016 6:47 PM
L1NO:
I'm quite sure that Karel knows that. :)
L1NO
Posts 250
L1NO replied on Wed, Nov 16 2016 9:18 PM
Made me wonder when 'fluid bits' arrose in context. All the power to good interconnects ofcourse.
kuyttendaele
Posts 707
L1NO:
L1NO..  I was only joking in that last paragraph.. was waiting untill someone would take it for real... :-) :-) :-) :-) I know... humor is sometimes difficult online.
L1NO
Posts 250
L1NO replied on Fri, Nov 18 2016 11:21 AM
Got quite the hardburn over here. 😂
Page 1 of 1 (17 items) | RSS
