S3 update
This post has 1 Reply | 0 Followers
mkappe
Posts 1
mkappe Posted: Mon, Nov 14 2016 6:11 PM
Hi everyone
I bought two S3 to use with my projector but have some difficulties with them.
First: when I connect the master speaker with an aux cable and it has a wireless pairing it does not play any sound at all. Once I've reset it to factory settings (B&O + "minus" for 6 seconds) it will play. As soon as I try to connect it to the second one they both go silent.
Also: The software update does not work. I downloaded the "BeoPlay Software Update" from the site and followed all the steps. But as soon as I turn on the S3 that I connected to my mac the light goes out and the S3 turns into a brick until I pull the plug, wait for a minute and then reconnect it.
Anyone else experience these problems? Any suggestions.
Thanks in advance.
Pindsen
Denmark
Posts 49
Pindsen replied on Sun, Aug 29 2021 6:58 PM
I also have problem updating the software in my S3. Did you find a solution?
/Pindsen
Page 1 of 1 (2 items) | RSS
