Apple Music and Multiroom
This post has 11 Replies | 1 Follower
Austin
United States
Posts 136
Austin Posted: Sat, Nov 19 2016 5:17 PM
I'm still a little confused on how multiroom works. I'm getting an Avant 55. If I'm steaming from the Apple Music Apple TV app or streaming airplay to my avant, can I distribute that sound to the A9 mk2? I assume you can link the A9 to any audio the avant is playing?
egges
germoney
Posts 303
egges replied on Sat, Nov 19 2016 6:20 PM
the Avant itself can't Airplay, at least mine bought in march this year. distributing apple music via Apple TV on hdmi through the system is no problem at all
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Austin
United States
Posts 136
Austin replied on Sat, Nov 19 2016 7:36 PM
So by tapping the top of the A9, it will start playing what the avant is? Can I also use the BeoMusic app to send that music to the A9?
Thanks in advance for your help!
zerocool143
Posts 94
you cannot share the music if you are using airplay.
elephant
AU
Posts 8,219
elephant replied on Sun, Nov 20 2016 7:29 AM
zerocool143:
In the OP's first scenario. The Apple Music App on the Apple TV is communicating to the Avant via an HDMI.
Therefore can another room "join" the Avant's audio ?
BeoNut since '75
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Nov 20 2016 10:08 AM
elephant:
I can JOIN the ATV audio connected to a BV11 in NL. Never tried this with Apple Music though (never had the urge to start a free period on Apple Music).
Just tried to JOIN ATV's "Music" (not Apple Music) playing on the BV11 to other NL devices. Result it does work!
zerocool143
Posts 94
This will work since your are distributing a HDMI source from the TV. But there is a restriction for Airplay to be distributed in multiroom setup. Better use the same account to your ATV that has the Apple Music subscription in order to share the sound in a multiroom setup.
elephant
AU
Posts 8,219
elephant replied on Sun, Nov 20 2016 12:06 PM
Conclusion I think is use B&O to distribute sources and inject airplay into the ATV as a once-removed source.
BeoNut since '75
Austin
United States
Posts 136
Austin replied on Sun, Nov 20 2016 1:54 PM
Sounds like using the ATV app is the way to go. Should I worry about burn in on the Avant if I always displaying album art?
egges
germoney
Posts 303
egges replied on Sun, Nov 20 2016 2:24 PM
i prefer to switch the picture off because the switching of the covers every ten seconds drives me crazy
elephant
AU
Posts 8,219
elephant replied on Mon, Nov 21 2016 10:45 AM
I think it eventually goes to the HD movies that are the automatic ATV screen savers.
BeoNut since '75
egges
germoney
Posts 303
egges replied on Mon, Nov 21 2016 1:02 PM
quite right, elephant. there are a lot of settings possible with the ATV screensavers, of course to use a fotostream of your own
Page 1 of 1 (12 items) | RSS
