Why was Google Cast not added to the smaller Beoplay speakers?
This post has 10 Replies | 0 Followers
daneshpastry
Toronto
Posts 42
daneshpastry Posted: Mon, Nov 21 2016 4:34 PM
The only thing holding me back from investing in some of the smaller Beoplay speakers (ie - the Beolit 15) is the lack of Google Cast implementation.
Can anyone tell me if there is a technical reason why the larger, all-in-one speakers got it, and the smaller ones did not? I realize I can add a Google Cast Audio dongle, but I use the 3.5mm aux input for my computer.
Qualification - I don't mind using bluetooth, but I feel like wi-fi streaming is better (gets source directly from internet, no phone battery drain, less compression, etc. etc.)
BeoMegaMan
Posts 601
The easy answer is they are Bluetooth only. All WiFi enabled BeoPlay products received the update for Chromecast.
Ah, you know... A little B&O here, a little there
leosgonewild
Helsinki, Finland
Posts 2,373
I like using the CA with my Beoplay speakers. I am constantly streaming to all of them. I just turn on the speaker when I enter a room.
But I see your point.
daneshpastry
Toronto
Posts 42
Pardon my ignorance, what is CA?
Millemissen
Flensborg, Denmark
Posts 14,680
CA = Chromecast Audio
https://www.google.com/chromecast/audio/
daneshpastry
Toronto
Posts 42
Gotcha, I thought they changed the name to Google Cast.
daneshpastry
Toronto
Posts 42
steve1977
Posts 911
steve1977 replied on Mon, Nov 21 2016 11:18 PM
BeoMegaMan:
what about the beolit 12?
leosgonewild
Helsinki, Finland
Posts 2,373
That *** unit is not getting any updates ever again.
Irvine
Posts 61
Irvine replied on Sat, Mar 25 2017 10:51 PM
 So, if I understand you correctly, you can use Google cast with the Beolit 15? You just need to buy the Google chrome cast audio dongle and plug it in to the 3.5 mm Jack? Is that how it works? How good is the sound quality? Since it is going through a 3.5 mm Jack, is it reduced?
Millemissen
Flensborg, Denmark
Posts 14,680
You'll be fine using a decent cable.
Never heard any complaint there.
Page 1 of 1 (11 items) | RSS
