My Tv is asking for a pin number
jenni
Posts 1
jenni Posted: Mon, Dec 5 2016 11:31 PM
My son was staying overnight and turned off the tv at the socket. When I went to use the TV today it asked for a pin number. We have never had to do that before. Tried the standard 0000 to no avail. Any suggestions?
BeoNinja
Posts 19
CONTACT BANG & OLUFSEN WITH YOUR SERIAL NUMBER TO REQUEST THE PIN. IT IS TO PROTECT THE CUSTOMER FROM THEFT... BUT IF PIN IS FORGOT WILL NEED ASSISTANCE FROM B&O OR RETAILER YOU PURCHASED FROM. GOOD LUCK.
zerocool143
Posts 94
jenni:
May I know what is your TV ? If its Beovision 7, you need to put that 00000 in the Mastercode. You need to press and hold the rewind button( << ) and wait to show the master pincode input. Hope it helps. Cheers!
Millemissen
Flensborg, Denmark
Posts 14,680
The mastercode won't help you much, since it is meant for use while servicing and only lasts for 3 hours (if I remember correct).
If you did not change the PIN yourself, you should have been given it by the seller.
Please have a look at your receipt.
In case you bought from a B&O store, please contact this - they might have the original code in their system.
If anything fails, do contact your local store (as mentioned above).
Be sure to have your receipt/serialnumber at hand.
Once you have PIN-coded it again be sure to write the code down and keep it safe ;-)))
Or decide not to activate the PIN code system.
Page 1 of 1 (4 items) | RSS
