How can one identify the different versions of Beosound 9000 I know about MkI, MKII and MKIII are there more..?
The best way is by four digit "Type" number
For the UK the type numbers are: Mark 1: 2522, Mark 2: 2562, Mark 3: 2572
You will find the Type number underneath the Control Panel, just remove the front control panel to see the data
Regards Keith....
Look at the label under the keypad:
Mk1 is 252*
Mk2 is 256*
Mk3 is 257*
