Which RIAA support amp goes with a BG8500 which I have linked up to a BM6500 and can someone remind me where to buy to support amp pls? Thank you in advance. Henrik
Where to buy it depends on where you live. A cheap solution with DIN sockets could be this one...
https://elektronik-lavpris.dk/p32067/bn200703-dynavox-tc-4-riaa-forforstaerker/
If you want higher sound quality, you can buy some more expensive RIAA amps.
Almost any RIAA amplifier could be used between your Beogram and Beomaster. But for most amps. you'll need some DIN/Phono adapters.
Try Google RIAA amp to find where to buy them.
PS: You'll have to remove two of the seven pins in the DIN plug from the Beogram.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
