Beovision 8-32
Kristinng
Posts 2
Kristinng Posted: Mon, Dec 12 2016 9:44 PM
Hi I'm new to this forum. I just bought a beovision 8-32 tv. I have a small problem with the tv.
When in dark room the light sensor turns the backlight to low.
So my question is, can I disable the sensor? And how.
Other question. How can I change to another setting like cinema or dynamic?
I have the beo4 remote.
Hopefully someone can assist me with this.
Regards Kristinn from Iceland
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Dec 13 2016 1:01 PM
Hi - I have the same and disabled the light sensor - goto menu, scroll down to picture or sound, enter 0,0 then press Go, select Monitor, go to Picture Adjustments and you should be able to switch off light sensor in there. You're software might be slightly different as I haven't got the picture you have.
Great set by the way
Kristinng
Posts 2
Kristinng replied on Tue, Dec 13 2016 9:19 PM
Hi Andrew, thank you very much. That worked, now the tv is perfect!Smile
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Dec 13 2016 10:41 PM
... and welcome to BeoWorld - the place to get your questions answered! Big Smile
The BeoVision 8, in my opinion, is an underrated TV and a complete bargain at the prices they're making.
Lee
Page 1 of 1 (4 items) | RSS
