BS2500 clock
This post has 5 Replies | 0 Followers
Silou
Switzerland
Posts 465
Silou Posted: Mon, Dec 26 2016 4:33 PM
hello,
2 questions:
- How to setup the BS2500 ' Only with the BL5000? Does BEo4 BEO5  ok?
- How display the time on the BS2500 ?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
You can use the BeoLink 1000 or 5000 remote controls as well as the Beo4 Beo5 and Beo6 to control your BeoSystem 2500
As far as I am aware you cannot display the time on the display on a BeoSystem 2500
Regards Keith....
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Dec 26 2016 6:38 PM
as Keith wrote every B&O remote starting with Beo 1000 can be used to control the BeoCenter / Beosystem 2500. But only the Beolink 5000 and the Beolink 7000 can be used to read and set the clock on the remotes display, even timers are possible but only on hthe display of one of the two Beolink remotes
Ralph-Marcus
Silou
Switzerland
Posts 465
Silou replied on Mon, Dec 26 2016 6:50 PM
Thanks Keith,
Of course it's possible for BEO4,5 for the basics function. But to set up the time it's with BL5000.
What are the equivalent functions on BEO5 ?
And for displaying the clock, ok, I thought about that because see I saw nothing into the user manual. But the function is available on the ouverture
Silou
Switzerland
Posts 465
Silou replied on Mon, Dec 26 2016 8:06 PM
Sorry RaMaBo,
I saw just now your answer.
You see the time on the BL5000 or the BL7000 right?
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Dec 26 2016 8:15 PM
yep :)
5000 & 7000 show the clock and allow the timer settings to be done.
In the Reference Manual is the handling shown with the Beolink 5000.
Ralph-Marcus
Page 1 of 1 (6 items) | RSS
