Any ideas how to push play on BeoGram with remote via NL/ML?
alex_112
Posts 38
alex_112 Posted: Sun, Jan 8 2017 1:20 AM
Hi!
I got one mission in life, I want to be able to press play on a BeoGram via newer gear, ideas? Currently got a Beogram 3000 tangential turntable which had been new in box until I got a hold of it Stick out tongue, I love it but would willing to change based on answers.
Possible?
BR
  //Alex
BV14, BV10, BeoGram 3000, 4500, BS 9000, Moment, Core, Ouverture, Essence, Beo6, BROneBT, BeoTime, ML/NL, BLGW, BeoLab 2, 11, 18, CX100, BeoPlay A6, M3, E8/H3/H8
Kromer
Randers, Denmark
Posts 129
Kromer replied on Sun, Jan 8 2017 10:21 AM
On page 11 there is a suggestion for just that for the 6500 system. http://beointegration.com/uploaded/Idea_Catalogue_v3.2.pdf
Not sure if you can make it work with your bg 3000 and a bm 5000/5500 too, by adding an ir code converter.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Jan 8 2017 11:16 AM
The Beogram uses Datalink for its remote and has no IR. The control is done by the Beomaster. The older MCL equipment however has a socket for the Beogram which has Datalink so might be a work around.
Peter
alex_112
Posts 38
alex_112 replied on Sun, Jan 8 2017 12:05 PM
I'm gonna grab a 1656 and a 1611 today to see if I get it working. Was thinking the signal could go over data link from the beogram directly to the converter and get play signal via masterlink?
BR
  //Alex
alex_112
Posts 38
Doesn't seem to work with the Play button on the IR-eye -> BeoLink Active via ML -> BeoLink Converter 1611 via DataLink -> Beogram. Neither does the N.Radio on the remotes all though they are clearly received.
I guess the N.Radio command sent via the eye directly to the phono is not the same as the command sent by my BeoMaster 3000 (which I connected for testing).
Ideas?
Page 1 of 1 (5 items) | RSS
