Beoremote one "crackling noise"
PeterBOBP
Posts 133
PeterBOBP Posted: Mon, Jan 9 2017 1:15 PM
I have a Beoremote one (first version, came with the V1) and it is making a cheap "crackling" noise when I push its buttons. A bit difficult to describe well, but it sounds a bit similar to the sound a plastic bottle makes when you squeeze it, although more muted. Not sure when it started; the remote is 1+ year old.
Anyone else has this problem? Is it normal (I do not think so)? Did you return it and was it solved?
Thanks!
Peter
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 9 2017 1:23 PM
I think I had that problem. I swapped with my dealer, but he called me a day later and said it was easy to fix. Think he just pulled out the black part and put it back gain.
PeterBOBP
Posts 133
Thanks Hiort for your quick reply. I will try that. Peter
Page 1 of 1 (3 items) | RSS
