I'm planning to buy Beovision 9 in next 2 to 3 months (moving to new appartment).
2 questions - isn't it too big for 55sqm living room ? plus what are the differences from MK2 till MK4 ?
Second option also was Beovision 4-65 with BeoSystem 3 but from purely esthetic POV BV9 is clear winner ... technically comparable ?
thx
Marek:I'm planning to buy Beovision 9 in next 2 to 3 months (moving to new appartment). 2 questions - isn't it too big for 55sqm living room ? plus what are the differences from MK2 till MK4 ? Second option also was Beovision 4-65 with BeoSystem 3 but from purely esthetic POV BV9 is clear winner ... technically comparable ? thx
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hi Marek,
here you will find an explanation from 9 Lee:
http://archivedforum2.beoworld.org/forums/p/20285/166249.aspx#166249
I had a BV9 for many years. It's a fantastic TV and it worked without any problems. The ACM-Camera automatically adjusts the Picture qualitity.
Digi
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
Michael: Marek: I'm planning to buy Beovision 9 in next 2 to 3 months (moving to new appartment). 2 questions - isn't it too big for 55sqm living room ? plus what are the differences from MK2 till MK4 ? Second option also was Beovision 4-65 with BeoSystem 3 but from purely esthetic POV BV9 is clear winner ... technically comparable ? thx Don't forget plasma looses brightness and quality over time. Not so sure it's a good investment anymore.
Well I'm not sure that's always true - I have a Pioneer Kuro 8th gen from 2008 that's been used more or less daily and the picture quality remains exceptional. Not 4K, or 3D or whatever of course, but a very good picture even by modern standards.
As for the BV9, it's a big object and of course not really up to date either but it's still (IMHO) a great TV and beautiful object in its own right - although I actually preferred (aesthetically) the BV5 since the curved 'frame' on the BV9 doesn't look quite as classy (IMHO).
MK I and II are HD-Ready (and therefore cheaper). MKIII and higher are FullHD and have the ACM (Camera inside frame).
MKIV has the newer AST sound option in the BS3.
Beobuddy:MK I and II are HD-Ready (and therefore cheaper). MKIII and higher are FullHD and have the ACM (Camera inside frame). MKIV has the newer AST sound option in the BS3.
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
