Playmaker and Beomedia 1
This post has 17 Replies | 3 Followers
Heribert
Vorarlberg / Austria
Posts 804
Heribert Posted: Thu, Aug 16 2012 8:23 AM
Hello,
Would the playmaker work with my Beomedia 1? Means would it play the Music stored on my BM1 and would it use the N.Radio function of the BM1.
Would all this work with the BS5E?
Especially the N.Radio function is important for me (which is basically the reason I own the BM1). I do not have great experiences with iTunes Internet radio from my IMac.
Thanks, Heribert
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Paul W
London
Posts 1,810
Paul W replied on Thu, Aug 16 2012 1:11 PM
Hi Heribert,
I'm sorry that I can't help you with your question, but, do you have the B&O BeoPlayer app for the iPhone? I love the 13,000 radio stations on offer with the app.  The radio section in iTunes is excellent. You can drag your favourite station over to your playlist library for easy location etc.    Food for thought I guess :)
PhilLondon
London
Posts 3,637
The BM1 isn't by default a UPNP/DLNA server. but I bet it isn't too difficult to install one on it. It is a window box after all. I have installed additional software on mine.
Then you'd need a controller. An iphone or android phone would do the trick.
Beoworld app with direct photo upload and emoticons.
Heribert
Posts 804
Heribert replied on Thu, Aug 16 2012 4:05 PM
Hmm. I was Searching a little to find a DLNA server for WIN XP embedded but was not really successful. Do you know any working one that does also have a iPhone app for it?
hfat
Vienna, Austria
Posts 663
hfat replied on Thu, Aug 16 2012 4:10 PM
I have installed the xp version of iTunes on BM1. So this could be an option to use airplay for you.
hfat
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Aug 16 2012 5:21 PM
hfat:
hfat
try Twonky.
It is also used on the BM5
Heribert
Posts 804
Heribert replied on Thu, Aug 16 2012 7:07 PM
Carolpa:
try Twonky.
I did try with Twonkey 7.1 and failed. I cannot acces from the iPod Twonkey beam app to the BM.
I also installed iTunes and registred it for the homeharing, but Remote Apps on iPod or iPad could not connect (after first connect). It shows the iTunes Logo in Remote, but without name and cannot connect...
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Aug 17 2012 6:08 AM
Here is a link decsibing the procedure to connect a device via remote app.
One the connection is enabled you simple start remote an play your misic.
hfat
Heribert
Posts 804
Heribert replied on Fri, Aug 17 2012 6:50 AM
Thanks a lot for the link. I know the procedure and did it several times before, but I fail to do on the BM1. I also disabled the virus scanner and windows firewall of BM1 but without success.
In the Remote app I can see a new device, but it has no name and cannot be found from the iDevice.
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Aug 17 2012 8:37 AM
Can you see the iDevice in iTunes?
Can you enter the Passcode?
Which version of iTunes do you use?
hfat
Heribert
Posts 804
Heribert replied on Fri, Aug 17 2012 9:03 AM
i can see the iDevices in iTunes and entered the passcode. further I can see a new device in Remote on the iDevice but it does not show the any name and cannot be connected....
I downloaded the latest available iTunes from apple.com for XP
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Aug 17 2012 9:47 AM
Sorry for the question, but did you activate your iTunes library for sharing?
hfat
Heribert
Posts 804
Heribert replied on Fri, Aug 17 2012 9:58 AM
i did  i can see the shared iMac Library in Beomedia, but not the Beomedia Library in the iMac
When I was trying to share Windows Media player Library I received an error without any information  is there any network thing I need to allow?
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Aug 17 2012 10:27 AM
As far as I remember I there was no need to change anything in the network configuration when I installes iTunes on my BM1.
I will check in the evening, when I get home.
hfat
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Aug 17 2012 7:34 PM
Hi Heribert,
I'm using iTunes 10.4.1.10 and have the firewall enabled. Exeptions are allowed and are set to: Service Bonjour, iTunes and File and Print Services.
Additionally I added entries for iTunesHelper and iTunes in the registry under: HKLM\Software\Microsoft\Windows\Current Version\Run to start iTunes automatically at boot time.
Check your system for the following Services, which must be started:
Apple Mobile Device
iPod-Dienst
Dienst "Bonjour"
hfat
Heribert
Posts 804
Heribert replied on Sat, Aug 18 2012 7:22 AM
It is very strange. I do have the same settings and it still does not work. I am near to make a restore on the BM and start again. As I bought it used the former user perhaps made some network setting that prevents me from connecting iTunes from remote.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Aug 18 2012 4:15 PM
Heribert:
Carolpa:
try Twonky.
You cant access the server with Twonky Beam to play music you need Twonky Mobile or another app like 8Player (there are a lot more out there)
Twonky will do the trick for sure
Another option is to install XBMC on the BM1. With the right XBMC settings it will work also.
hfat
Vienna, Austria
Posts 663
hfat replied on Tue, Aug 21 2012 6:16 PM
Hi Heribert,,
I've setup a second iTunes on another PC (latest version) and ran into the same problems. I found out that is caused by some network circumstances. When indirectly connected to my timecapsule everything works fine. When I connect via a network repeater which extends my wlan, the problems you described where shown.
I found the following work around:
On my iOS devices I deavtivated home sharing and connected each device indivdually to both iTunes libraries.
Then I reactivated home sharing (this step is optional).
Although the media libraries in the remote app are shown as inactive (greyed), connection can be esteblished.
hfat
Page 1 of 1 (18 items) | RSS
