Essence MK2 and WD NAS
This post has 6 Replies | 0 Followers
Mr 10Percent
So West, Its Now East
Posts 591
Mr 10Percent Posted: Sat, Jan 21 2017 12:53 PM
Hi Folks.
I'm having a few issues with the Essence MK2, BeoMusic App and a WD 4100EX NAS (with embedded Twonky) installed in the office.
The NAS, Essence and all LAN connected. I'm signed up to TuneIn.
Bottom line is that the BeoMusic App is showing the NAS Music Library as "Access Denied"! (greyed-out).
NAS is in streamer mode for that volume.
Twonky all looks OK in the advanced config setting.
Furthermore, the Avant works well with the NAS library and pulls files without issue.
Any ideas?
10
elephant
AU
Posts 8,219
elephant replied on Sun, Jan 22 2017 7:16 AM
I can't help (no experience) but I have always considered my next step should be nas but keep buying WD standalone models and so I have a (insert collective noun) of drives Big Smile
I am interested in what answers you get ... certainly your WD got a reasonable review:
"Pros
Easy to use UI
Wide range of accessibility
Strong 8k 70/30 RAID10 iSCSI performance
Cons
Low performance in our 8K sequential tests.
The Bottom Line
The WD EX4100 is targeted at creative professionals and multimedia enthusiasts that have the need for high capacity and flexibility of access with an easy to use interface.
BeoNut since '75
Mr 10Percent
Posts 591
elephant:
"Pros
Easy to use UI
Cons
The Bottom Line
Unfortunately, I have no experience of other NAS mainstream manufacturers. the MyBook series were rubbish with a bad UI in my opinion and kept biting (killing) its own WD Red HDD. I thought this would be safer with the WD EX4100 - which I use as JBOD rather than RAID.
They are slow to load (OK as a music server) all your data initially and again, the interface is clunky and hard to understand. however, once mapped to my Windows, it does it job.
context: can't tell if it really is good or bad. But to me the product could be a whole lot better.
10
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Jan 22 2017 1:07 PM
go to Beomusic app
select Essence
log in to TuneIn
start a radio broadcast.
Does it work?
then look at your NAS music again, still greyed out?
Mr 10Percent
Posts 591
Carolpa:
go to Beomusic app
select Essence
log in to TuneIn
Does it work?
Tried all that plus a few re-installs of BeoMusic and resets of Essence.
It is not so much greyed-out as it explicitly states "access denied"
10
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Jan 22 2017 1:47 PM
Mr 10Percent:
a picture please
look in your NAS if it doesn't block DLNA controlers
Mr 10Percent
Posts 591
Problem appears solved.
The WD NAS has the ability to have a general DNLA switch where you can select devices to stream to and a DNLA switch for each volume you wish to stream media from. All those were already flicked on as required.
However, on the iOS (btw I just don't see what the rave of Apple/iOS stuff is all about - give me Microsoft any day of the week) settings, I flicked the "Allow BeoMusic to access Music library (I have zero iTunes or any media on the iPad as I use it for control purposes only), BeoMusic would then not connect to Wifi and re-acquire the Essence. Flicked it back on and "tah-dah"......... my NAS Library reappears and now its super fast streaming.
Weird stuff.
10
Page 1 of 1 (7 items) | RSS
