Problem with Beomusic and Deezer
This post has 4 Replies | 0 Followers
Erik
Stockholm
Posts 9
Erik Posted: Sat, Jan 21 2017 3:37 PM
Hi
Today i notice a problem using Deezer through the Beomusic app.
Every tune just play 30sec and then change to next tune.
Have i unfortunately change any settings?Unsure
Regards Erik
Razlaw
Posts 4,345
Razlaw replied on Sat, Jan 21 2017 3:47 PM
I have had the same problem. Try logging out of Deezer in the app and then log back in.
petrosbeli
Posts 64
Sounds like your Deezer subscription has expired and you are on the "free" tier. You need a Deezer Premium+ subscription
Razlaw
Posts 4,345
Razlaw replied on Sat, Jan 21 2017 10:08 PM
Not necessarily expired. I have had the exact same problem multiple times. Merely have to re log in an problem is solved.
Erik
Stockholm
Posts 9
Erik replied on Sun, Jan 22 2017 7:02 AM
Thanks it worked to log out and in again.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
