Beomaster 900 (M?)
gurth
Posts 14
gurth Posted: Sat, Jan 28 2017 4:27 PM
Hello.
I have recently purchased a working Beomaster 900 from eBay as I liked the look of it. The guy I bought it from did house clearing and this came up so I put a cheeky offer in and he accepted it.
The radio is sitting proudly on my dining room and I use it most evening in front of the fire ;-)
I have noticed recently the light bulb behind the display has failed so I would like to open it up and replace but I'm not 100% sure how to open the radio? There are 4 screws on the base which I removed but I couldn't workout how the chassis came out of the wood case. So I decide to leave for now and do a little research on the web....
Any suggestions on the recommend approach?
Thank you in advance.
CB
> You are Here <
Posts 1,762
CB replied on Sat, Jan 28 2017 7:20 PM
Hi, and welcome to Beoworld (first) and to the BM900 owners club Yes - thumbs up
Once you removed the four screw, remove the four front knobs (the are fixed by tiny screw) and then pull the black rear panel out. Everything will come with it.
Be just careful with the wires...
The 3 light bulbs are 7v if I remember well. Dillen can certainly sell you a set.
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Jan 28 2017 8:34 PM
The service manual is on site for silver and gold members.
Peter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 29 2017 7:59 AM
The MPX lamp is 18V.
I can supply correct lamps.
There are two versions of Beomaster 900, the early version with flat grey front and the later darker version with
offset front  (as CB is showing).
Only the later one needs the knobs removed.
gurth
Posts 14
gurth replied on Sun, Jan 29 2017 8:37 AM
Thank you for the warm welcome!
I'll try and sit down this afternoon and open the case. I found this mention of bulbs earlier:
http://archivedarchivedforum2.beoworld.org/forums/t/31068.aspx
gurth
Posts 14
gurth replied on Sun, Jan 29 2017 8:42 AM
Mine doesn't have the integrated speakers, instead it looks like this:
The knobs on the front do have a small screw hole in them so that must be how I remove them to let the chassis slide out the back.
Page 1 of 1 (6 items) | RSS
