Avant 55 PUC control issue
This post has 4 Replies | 0 Followers
BeoNinja
Posts 19
BeoNinja Posted: Thu, Feb 2 2017 1:11 AM
LIve on the west coast and have not been able to find the correct PUC code. Trying to control the comcast X1 box...Does any one have suggestions?
Thank you.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
There are no Comcast PUC's in the B&O library.
However, the box is going to be made by someone other than Comcast. You need to establish the box manufacturer, but my guess is that it will be Pace. See if your box has an actual model number on it.
If that fails, you could just try one of the Pace PUC's as most of them use the same IR codes for the basic controls
Regards Keith....
BeoNinja
Posts 19
BeoNinja replied on Fri, Feb 3 2017 10:28 PM
Thank you!
BeoRTB
Posts 9
BeoRTB replied on Fri, Feb 3 2017 11:33 PM
If it has the DVR use "US Generic Cable 6".  If it does not have the DVR use "US Generic Cable 4".
BeoNinja
Posts 19
BeoNinja replied on Sat, Feb 4 2017 12:06 AM
Thank you.
Page 1 of 1 (5 items) | RSS
