Hello. My DVD recorder has bitten the dust, and I'd like to progress to video streaming from sources like Netflix. I have a Beovision 8/26 (2009 vintage). I'm thinking of using an Amazon Fire TV, connecting through the B8's HDMI port. My broadband download speed varies between 4 and 8, and I would link to the router via Ethernet rather than Wifi. Are these components going to be compatible, and how will I get over the HDCP restriction?
Please bear in mind I'm not at all tech-savvy, so please don't assume any more than the most basic of knowledge if you reply. Thanks.
Hi Wordspace and welcome to Beoworld.
That should not be a problem.
The HDMI interface is made for this kind of connection.
Always use wired for network, if you can.
Have fun with your BV8-26.
Millemissen: Hi Wordspace and welcome to Beoworld. That should not be a problem. The HDMI interface is made for this kind of connection. Always use wired for network, if you can. Have fun with your BV8-26. MM
Am I correct to believe that this TV model is not equipped to deal with HDCP? If so, would a simple HDMI splitter overcome the restriction?
Wordspace: Am I correct to believe that this TV model is not equipped to deal with HDCP? If so, would a simple HDMI splitter overcome the restriction?
What makes you think so?
And why would a splitter help (if help was needed)?
I think a simple solution for you is to use a decent HDMI cable and see if it works. The ethernet cable will connect to the amazon fire TV, and the HDMI cable will connect to the BV8 via the HDMI port. The only potential issue I see is if yo uwant to control the Amazon Fire TV with the B&O remote, you'll have to potentially take your BV8 to a dealer to update the PUC for use with the FireTV, as you can't update the PUC table on your own.
Sal: I think a simple solution for you is to use a decent HDMI cable and see if it works. The ethernet cable will connect to the amazon fire TV, and the HDMI cable will connect to the BV8 via the HDMI port. The only potential issue I see is if yo uwant to control the Amazon Fire TV with the B&O remote, you'll have to potentially take your BV8 to a dealer to update the PUC for use with the FireTV, as you can't update the PUC table on your own.
My friend Sal is correct about possibly needing to have the PUC updated. We all cringe when we think about the need to send a BeoVision or BeoSystem to an authorized service center to be updated. It can be a little costly. $300 USD is not unusual for an update. Maybe less if you have a good relationship. Therefore, sometimes it's nice to look at solutions that can work WITHOUT the need for a PUC update. I have a BeoVision 8 at my law office. It didn't have much in the PUC when I bought it. However, a very nice little trick about the Apple TV is that the Apple TV can learn IR commands generated by devices that ARE in the BeoVision 8 PUC. This works beautifully. While not an Amazon Fire, the Apple TV can provide you with Netflix, Hulu, and just about anything else you need. I can attest that the BeoVision 8 HDMI has no problem with the HDCP with the Apple TV.
beojeff: Sal: I think a simple solution for you is to use a decent HDMI cable and see if it works. The ethernet cable will connect to the amazon fire TV, and the HDMI cable will connect to the BV8 via the HDMI port. The only potential issue I see is if yo uwant to control the Amazon Fire TV with the B&O remote, you'll have to potentially take your BV8 to a dealer to update the PUC for use with the FireTV, as you can't update the PUC table on your own. My friend Sal is correct about possibly needing to have the PUC updated. We all cringe when we think about the need to send a BeoVision or BeoSystem to an authorized service center to be updated. It can be a little costly. $300 USD is not unusual for an update. Maybe less if you have a good relationship. Therefore, sometimes it's nice to look at solutions that can work WITHOUT the need for a PUC update. I have a BeoVision 8 at my law office. It didn't have much in the PUC when I bought it. However, a very nice little trick about the Apple TV is that the Apple TV can learn IR commands generated by devices that ARE in the BeoVision 8 PUC. This works beautifully. While not an Amazon Fire, the Apple TV can provide you with Netflix, Hulu, and just about anything else you need. I can attest that the BeoVision 8 HDMI has no problem with the HDCP with the Apple TV.
That's a great point! I always forget that the ATV has that feature!
Thanks to everyone who replied. Sadly, in spite of reassurances, with both the Amazon Fire Stick and Apple TV I was unable to see video from a GooglePlay streamed series. Instead I got the typical HDCP prohibition screen.
Interestingly, if I open my YouTube account on my iPad the purchased series is there. I link the iPad to the Beovision 8's HDMI port and it works.
I don't mean to be contentious – I asked for advice and am grateful for any advice that is forthcoming. I do want to add to the general fund of knowledge though.
Martyn[Wordspace]
