Help needed with my BV7 Mk 1
Crown
Posts 7
Crown Posted: Sat, Feb 18 2017 11:01 PM
Dear all,
I have a couple of questions for you regarding my BV7 32 Mk 1 (Type # 9314) which is now being used in a guest bedroom. I have noticed that there are some protruding marks appearing on the edges of the screen just underneath the glass. Upon close inspection I can see that it is not a pixel problem.
Could someone tell me the cause of this problem and if I'm advised to have it repaired before more serious problems might occur? Frankly, the problem is fairly minor for a TV which is nowadays used more for music than movies so the problem isn't critical but I am curious to understand it better.
Thanks in advance!
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Sun, Feb 19 2017 10:19 AM
The problem with the ATV2 might be due to HDCP which is not supported on MK1 models.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Rob - Danish AV
Melbourne
Posts 376
I had a similar issue, I was able to use a butter knife and move them away, they are soft pads I'm guessing to protect the glass from behind. They may have moved when you relocated to guest bedroom.
Page 1 of 1 (3 items) | RSS
