hello,
maybe it is done in an update of the beosound essence but I don't think so, I wonder why b&o doesn't update it with the n.radio function as they have done it recently for the bv 11, v1 40...
this is also a nl product.
that would be great.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
of course for any beosound essence mk1 or mk2
The 'n.radio function' in the Essence is different from the N.Radio in the BV's.
It is based on the TuneIN service and has been there all the time....even in the first gen.
What is it, that you are missing?
Hi MM,
Had made some search on the tunein database and I find the n.radio choice wider.
thanks
olvisab: Hi MM, Had made some search on the tunein database and I find the n.radio choice wider. thanks
Not sure, what you mean?
The TuneIn service appears as a source of the Essence, when you use the Beomusic app!
During the setup, log in to TuneIn with the credentials you have made for it, and afterwards the favourite stations made will appear there.
