Update of the Bang & Olufsen app released
This post has 88 Replies | 5 Followers
hadr
Switzerland
Posts 92
hadr replied on Fri, Mar 24 2017 8:34 PM
Seanie_230:
Hello MrAndersen
Just been playing with the app and playing music on my Essence Mk2
When I find a track from my fav's and select play next it does not do it it plays another track but I don't know where it's come from.
I have to select play now and it works
I submitted feedback BLGW - Rekindling the love of ML
I'm having the same "problem". Wonder where the songs played after come from, seem totally random and are certainly not "favourited".
I mostly use Deezer if that helps...
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Mar 30 2017 6:29 AM
I have been using the MoodWheel on the Moment a lot lately, but I cannot seem to figure out how it should work when combining the X app and MoodWheel.
I have posted some questions and findings here.
http://archivedforum2.beoworld.org/forums/p/25017/199984.aspx#199984
It seems that the PlayQueue in the X App and the Moment's MoodWheel does not know what to do about eachother (at least the MoodWheel) get's confused :)
Also, regarding the Radio part.. I find it very confusing that to actually being able to listen to radio stations, I need to put them in the Queue ? This makes no sense to me, because a station never stops. If the Queue is empty, and I select a radio station from my favourites, I cannot go to the next or prev station. to do this, I normally first go to the beomusic app, and select a song from my favorites there, that populates the queue in the X App, and then prev/next works.
That could be a lot better in the X App. Songs and radio are 2 very different things regarding listening and changing stations.
I also noticed, when adding an alarm to my A6, that if the A6 is off, and adding the alarm, the TuneIn stations I could select, where NOT from my favorites, they seemed random, and at best, just the first 10 stations available.
Don't know if this is the A6 or the App, or a combination. If I turn on the A6 and selects a song from my favorites, then the list I can select in the Alarm, is my favorites list.
The App are a great step ahead, but I really think there are way to many "this works like this, because you did this", and not "this works like this every time".
I know there are many products and App's that need to work together, and this is not a small task :)
Looking forward to the next version :)
/Jacob
MrAndersen
Posts 226
Hi Webyx
We struggled a lot with radio and the queue structure on the products. You are right, in many ways radio stations doesn't make sense in a queue, as you say they never stop. The again it might, because it enables you to switch between the stations fast on the product or in the app. Then you have podcasts where the queue does make sense and you can actually combine them in the same queue, which is also a bit strange. In the end we decided to not make any assumption and force a specific user pattern on radio. We would let the users play around with it, using the build in playqueue concept, and get some user feedback, which we're now getting :) I do not yet have the magic bullet that will make radio work in the queue intuitively, we will adjust it over time and hopefully we will get there.
As for the radio favorites not working like they used to, we're aware of this and fixing it for the release in april. Stay tuned, pun intended ;)
Thomas, Bang & Olufsen
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, Mar 31 2017 6:13 AM
MrAndersen:
Hi Webyx
I know that it is not easy to implement everything so it works 100% for all people 100% of the time :)
The reason I get confused about Radio, is that since the dawn of time(1989 when I bought my BS4500), I have been used to the fact that when I listen to radio, and have preset 9 stations, the prev/next is cycling through those 9 "favorites".
This behaviour is what I believe most people using TuneIn expects. That it cycles through your favorites, unless off course, you choose another station. but that is just the same as searching for a FM station, and find out you dont like it, so you just go back to your favorites.
For me at least, the Radio stations in my favorites, should work 100% like the stations preset on an FM radio, they should not be added to any queue, they should be treated as the "old" days ;)
That is just my 2 cents, don't know if you have had a user group to talk to during the design of the app, but since there is a lot of "old" gold out there, that are loosing their FM radios in these times, and might just think about the move to newer times, they need to feel a bit at home with the new stuff, or they move to a simpler, cheaper, no-name DAB+ radio, and a customer is gone.
It is very important I think, that the new stuff is 100% intuitive, or it get's to hard for non technical people to use.
You are doing a great job, and I think that over time if the focus is kept, that the new X app and Moment, will really really be a nice combination for people to use.
And.... now I am talking about the Moment. Did you read my thread about my MoodWheel behaviour ?
Are the X app team , and the Moment in dialogue about the interaction between X app's play queue, and how it is transferred to the Moment, and the Moment's MoodWheel, and how it respons to the PlayQueue from the X App ?
I am getting som really really weird behaviour when combining the X App and MoodWheel. Those 2 together does not play well, and when I would like to use the MoodWheel, I first clear the PlayQueue on the Moment using the X App, it is the only way there is some consistency in what music the moodwheel gives me. If I don't clear the Queue, the music I listen to is a random combination of X App Queue/MoodWheel and the next ring it jumps to, when finding a song that is not in the same mood as I selected on the MoodWheel.
It is very easy to replicate the confusion :)
/Jacob
CB
> You are Here <
Posts 1,762
CB replied on Fri, Mar 31 2017 7:12 AM
Weebyx:
This behaviour is what I believe most people using TuneIn expects. That it cycles through your favorites, unless off course, you choose another station. but that is just the same as searching for a FM station, and find out you don't like it, so you just go back to your favorites.
+1
Henrik
Norway
Posts 165
Henrik replied on Fri, Mar 31 2017 8:10 AM
MrAndersen:
Really looking forward to the april update of the X-app. I'm axcited to see what progress you have made. Another possible issue to consider for the X-app. Don't think this has been brought up yet:
If you favourite an artist on Deezer, all the albums/EPs/singles of that artist are added to your album collection on the Moment. In a post march 12th in the "Beosound Moment v2.0 First Impression" thread Lyle Clarke explains the reasons for this. They are good reasons, some of which are Moment-specific and does not apply to the X-app, specifically the reasons pertaining to the Mood Wheel. No wonder then, that the X-app treats this in a different way, not adding all the albums to your album collection when you favourite an artist. A few of the other reasons apply though, such as quickly building an album collection from scratch.
However, this leads to inconsistent experiences concerning what albums I "have" and "don't have" in my album collection. I have listened to a specific album a lot lately, having started it from the Moment. However, when I wanted to start it from the X-app the other day I couldn't find it in my collection. First I thought something was wrong, and it took me half a minute to realise that I had favourited the artist, but not the actual album.
Not a bug as such, but maybe something that should be coordinated between your teams. Still in this brave new world of streaming I like to think of my album collection as something tangible, that I "have", and this inconsistency challenged that feeling more than I care for.
Thanks!
btw: I don't know if you saw my last comment in this thread, about sorting/filtering in the album view of the X-app. Did it make sense?
Have a great day!
Oh, and see you a the price draw, everyone! Big Smile
-h.
Chris
Ostend-BE
Posts 1,170
Chris replied on Mon, Apr 3 2017 5:45 PM
Large playlists (700 tracks) in Deezer are having problems to load them. The Android app keeps trying to load the tracks in the playlist view, but shows after a while a black screen, or a displays a fault message. There are no problems with loading smaller lists from around 100 tracks.
The only way to play a large list is opening the ... icon after the playlist name and push 'play now'.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
MartinRK
Posts 80
The new IOS 10.3 fixes the problems in the BeoMusic App with Essence mk I not connecting.
I just updated ny iPhone, and everything is back to normal 😀
djfairley89
Posts 20
MrAndersen:
Hi all,
Today we have updated the iOS app in the app store. The app have received a lot of polish and couple of new features. So here is a couple of words on that:
We have improved the transitions between the different views to be more fluent, especially regarding the header. The player drawer (our internal name for the small grey bar in the bottom) has been refactored to have information on the selected product. That means no more snackbar messages on disconnected products All standby has been added We have added simple TV support for BeoVision 11, BeoVision Avant, BeoPlay V1 and BeoSystem 4. This first implementation is very slim and only supports volume, channels, sources and expand. We do NOT support "wake on lan" and "my buttons" yet. Our TV support will evolve over time and this is the first step. Expand has been redesigned to have a more clear separation between selecting a product and expanding to another product.
The app is still very new and bit rough around edges, our next release is planned for April so stay tuned.
Thomas Andersen, Bang & Olufsen
PS. The updated Android app will hit the Play store tomorrow, we will keep them in sync from now on.
Love the new look and feel of the latest App. Also very impressed to see feedback being so quickly taken on board and implemented. A couple of things from personal experience that I think could be nice additions: (I'm not sure if others have already suggested, so apologies in advance if so)
- Would it be possible to add all standby from a long press on the centre of the wheel/pause/play? Small change but it would go in line with long press on traditional systems.
- I would also like the Ability to set a separate volume for alarms clocks as the default volume is not always appropriate.
Thanks,
David
Kiran
UK
Posts 1,023
Kiran replied on Thu, Apr 6 2017 9:07 PM
I am unable to see the BV Avant in the X app.
I also cannot see the NL/ML converter.
Will it stay like this?
Regards
Kiran
Born in NL; I ride ML
Millemissen
Flensborg, Denmark
Posts 14,680
CB:
Weebyx:
+1
A bit late to the party, but...
....I totally agree on this - this is the way it has to work.
A Radio station is not a playlist - it is a fixed stream, that you can add as a favourite/preset.
They easiest way to access the preferred radio station is to assign it to a number just like we do with a tv station.
Some like to access it directly, others like to skip through the list of favourites, but you need a fixed, easy understandable structure to do this.
jans
Belgium
Posts 394
jans replied on Wed, Apr 19 2017 9:25 PM
MrAndersen:
Hi Webyx
Hi MrAndersen
When can we expect the next release of the App? It would be great when the Radio favorites would work as expected
Jan
MrAndersen
Posts 226
Hi all,
Sorry i have absent for while. We're wrapping up the April release and will be shipping in a few days. Let me try to catch up with your questions. Let me know if i have missed anyone.
@Henrik: We're aware that the integration with the Moment is still not as it should be. The Moment behaves a little different in many many of the API calls and makes it really hard to get right. We will keep on it. In regards to the sorting and filtering, yes we hear you and are looking at solutions. Think we will start simple by simply have a free text filter and work from there. I'll keep you posted.
@Chris: That sounds like something we should look at right away. Not sure, but Deezer should have a paging functionality. Android seems to handle large lists much worse than iOS unfortunately. Creating a bug on it now.
@djfairley89: Thank you for the kind words, much appreciated. Currently all standby is only in Active Sources accessible from the player top right. I feel this is too hidden. Long press on play/pause might work but how would you know it is there? Separate volume for alarms is a must, I'm surprised it is not there. I will forward your request to the product team.
@Kiran: BV Avant NG is not in yet. Waiting on go ahead from the product team. We're working on the NL/ML but it is going to take a bit longer. The test matrix is daunting. Expect it this summer.
@Millemissen: TuneIn favorites will work like they do in BeMusic in the April release 0.9.5. As for the play queue, agreed we need to look at this. The queue concept for is a bit messy on the products and thats where we need to fix it. We're looking at it.
@Jans: Very close, in the next 3-4 days depending on platform.
Thanks for all your input
Thomas
Sandyb
Posts 2,186
Sandyb replied on Thu, Apr 20 2017 8:31 PM
Hi there Mr.Andersen......cant quite remember, but is DLNA support being added to the new app in the upcoming release?
Thanks for the communication
SandyB
MrAndersen
Posts 226
Hi Sandyb
Yes it is. We just finished the concept work and started coding. Expected out in May.
Thomas
MrAndersen
Posts 226
Ups too fast, no not the upcoming one sorry.
jans
Belgium
Posts 394
jans replied on Thu, Apr 20 2017 8:45 PM
MrAndersen, Thomas,
Thank you very much for your feedback! It is really great to have you (and thus B&O) being so close and transparent towards this user community! Truely a nice example of what is often referred to as 'co-creation'!
Based on your feedback I am really looking forward to seeing the upcoming releases of the App!
Jan
Millemissen
Flensborg, Denmark
Posts 14,680
MrAndersen:
Hi all,
Thomas
Hej Thomas,
there is another thread on the forum about the new app:
http://archivedforum2.beoworld.org/forums/p/23960/201731.aspx#201731
I posted a question on the app offering to use/configure Google Cast on my V1 tv there.
Would you be so kind to look into that as well?
Kiran
UK
Posts 1,023
Kiran replied on Fri, Apr 21 2017 6:57 AM
I can't wait for April's release. I am starting to use the X app more and more.
Regards
Kiran
ThatGuyFromDenmark
Posts 48
Me too, I'm starting to really like it.
There are a few features that I need to see before it's matured to me:
  • Shuffle option really needs to be present, as does repeat functions
  • Moodwheel integration would be really awesome. It's probably a product positioning thing, but nothing technical is stopping you to implement the MoodWheel in the app and thus bring it to the rest of the B&O portfolio. Personally I really like the MoodWheel, so to me it's a clear USP that should be pursued
  • Check for software updates... I'm a nerd, I want my updates, and I want it in one place
  • DLNA, as said before
Sandyb
Posts 2,186
Sandyb replied on Fri, Apr 21 2017 10:08 AM
Thanks for the reply
Is it likely the new app will work with QNAP NAS drives- I believe the BeoMusic app doesn't, which is a real shame
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Apr 21 2017 10:50 AM
Will the app be designed för iPad as well?
MrAndersen
Posts 226
MrAndersen replied on Fri, Apr 21 2017 11:05 AM
@Sandyb: We will test on all the major vendors, Synology, QNAP, Netgear, Buffalo etc.
@Hjort: Yes, concept work has begun. We will start coding very soon
MrAndersen
Posts 226
MrAndersen replied on Fri, Apr 21 2017 11:37 AM
@ThatGuyFromDenmark: Yes shuffle and repeat, still embarrassingly absent. We will add it, it just not only involves the app and that complicates it a bit. Moodwheel, well perhaps at some point. It is not on the roadmap yet. Software update, you can see if your product is up to date in the product page->about. Not yet update it directly from there. This will be added. DLNA, yes work has begun.
Kiran
UK
Posts 1,023
Kiran replied on Fri, Apr 21 2017 12:54 PM
MrAndersen:
Please include Seagate too. Thank you 👍🏻
Regards
Kiran
digi
Bremen
Posts 75
digi replied on Sat, Apr 22 2017 11:40 AM
I totally aggree with Jan. Thumbs Up
Good Job MrAndersen!!!!!
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
BeoHut
Posts 482
BeoHut replied on Thu, Apr 27 2017 7:11 PM
The new update of the app is made available for download in the App.store.
Wow, what an improvement!!!! Very well done team!!!!!
I am very happy with the new features. Now playing with it.
One suggestion to add in the app: make it possible to start playing multiroom devices with one touch of a button (predefined by user in config-screen)
Gr. BeoHut
Kiran
UK
Posts 1,023
Kiran replied on Thu, Apr 27 2017 7:23 PM
Thanks for the update!
I can't wait to get home... 💯
Regards
Kiran
Seanie_230
UK
Posts 2,278
Mr Anderson
Today I updated the app
I renamed my moment previously and it changed in the app
Today it appears as a product again that is not reachable
Hope this helps, I have sent feedback via the app
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
MrAndersen
Posts 226
Hi Seanie
That looks weird. I will take a look at this tomorrow.
Thanks for feedback.
Thomas
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Apr 27 2017 8:59 PM
MrAndersen,
I raised a ticket for this one too: the Recommended playlists and artists section headers are showing technical fields names instead of the French value of these fields - Cheers
BeoHut
Posts 482
BeoHut replied on Thu, Apr 27 2017 9:00 PM
Strange, my Moment is visable (although using Avant speakers).
Some screenshots from iPad:
Edit: my Avant was offine when I took the screenshots.
elephant
AU
Posts 8,219
elephant replied on Thu, Apr 27 2017 9:56 PM
@BeoHut
Wow that's an impressive "Mijn Producten" collection Yes - thumbs up
You should become a beta-tester !
BeoNut since '75
BeoHut
Posts 482
BeoHut replied on Thu, Apr 27 2017 11:17 PM
Thanx Elephant Big Smile.
Some NL-products are double on the list, but in every room in the house (except in the small guestbathroom is a white BeoLit 12) is a NL-product. I enjoy the multiroom feature.
Haven't thinking about being a beta-tester. A white BeoPlay S3 is connected to my Mac or placed in my hobby/laundry room, connected via line-in to the Essence in the kitchen. A selfmade multiroomBig Smile.
All products are wired, even in the masterbathroomWink.
Would like a possibility to make a group of devices to start/stop playing without to join every product each time. Maybe in the new X-app!?Whistle
But still very happy with my beloved Beo-setupLets have a Party !!!, or should I say BeoHut?
I have a marvellous dealer!Yes - thumbs up.
Chris Hassell
London
Posts 396
Hi @MrAnderson - loving the app, have you any idea when you'll support the BV14 in multiroom?
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
MrAndersen
Posts 226
@BeoHut: Showing the speakers attached are not yet supported. Will be soon.
@Chris: Sorry, no BV14 yet, we have implemented support, but waiting for go ahead
bs206
Posts 66
bs206 replied on Fri, Apr 28 2017 12:06 PM
When i listen to the radio on my Moment, the App doesn't show what's playing on the Radio any more, even when i select another channel on the App.
Get black screen with the volume wheel.
Playing right now, with Deezer works fine.
Another addiction, when you start the app (Iphone), and lock your Iphone after. You can control volume, play/pause, previous/next on the lock screen, very pretty!
And when i make a phone call, when the App is running, it degrease the volume of the Moment till i hang up. Very pretty alsoThumbs Up
Kiran
UK
Posts 1,023
Kiran replied on Sun, Apr 30 2017 9:14 PM
Waiting for NL/ML Converter integration 👍🏻
Regards
Kiran
Stefan E
Sweden
Posts 101
Stefan E replied on Wed, May 10 2017 10:22 PM
MrAndersen:
I´ve a question related to DLNA. I´m not a owner of your latest NL products except for the NL/ML Converter but I wonder would it be possible to integrate with the BM5/BS5 or BS5 Encore since both of these acts as a DLNA receiver that can remotely start to stream the DLNA stream that you send to it.
I would be fantastic to be able to bring new life in these iconic products by a simple thing like that, by doing so you could include these as a partial multi room experience by using the older DLNA protocol.
Regards
Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
beojeff
USA
Posts 2,012
beojeff replied on Wed, May 10 2017 10:39 PM
Stefan E:
MrAndersen:
Regards
Stefan
+1!
I could never quite understand why the BeoSound 5 was not integrated into the multi-room system of NL. It's already connected to one's wifi network and is basically a computer that could accept a software update to achieve the goals. The BeoMaster 5 content already shows up in the BeoMusic app as a source for NL products.
Page 2 of 3 (89 items) < Previous 1 2 3 Next > | RSS
