Hi
The last four years I have been working in China where I have bought the Beolit 12 as it is such a good sound from a small package. Now I will move to Malaysia and having problem with how to ship the Beolit as it has a lithium battery inside.
Does anyone have any experience or solution on shipping a Beolit 12 or taking it with you as hand luggage?
Cheers
Same, have had it via hand luggage when traveling with it internationally, just pop it through the x-ray scanner with the rest of your carry on luggage, I normally have it in the original box.
Worked fine as hand luggage on international flight between Shenzhen/China and Kuala Lumpur/Malaysia. Only thing they wanted to check was the cable compartment but no problem once I open and they could see it was empty.
Just a quick update...
Worked well as hand luggage from Shenzhen/China to Kuala Lumpur/Malaysia.
Thanks for your support!
