Using generic BeoSound 5 cables
This post has 12 Replies | 2 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Sun, Apr 9 2017 5:56 PM
I thought this might be some useful info regarding the BeoSound 5 cables.
I recently got a 2nd BeoSound 5. The lazy person who removed if from the wall for the former owner cut all of the 3 cables. *GASP!* The horror!
As I was quoted $325 from B&O for 4.5 meter replacement cables, I though I would try some generic cables from Amazon.  I got a 3 meter mini-HDMI to DVI-D cable and a 10-foot USB to mini-USB cable all for less than $20 USD. I still needed get the third cable, the 4-pin power cable made by B&O, for $100. The generic DVI and USB cables worked just fine. While they may be a little too short for a wall installation, they work just fine for me for table-top use. I was able to save over $200 USD.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sun, Apr 9 2017 8:53 PM
Totally agree!  Save your money people..
We get a lot of BeoSound 5's in where the previous owner has chopped the cables (in fairness, they're not always lazy - sometimes they're plastered into walls or under floorboards).  We use high quality non-B&O cables, which still work out a fraction of the price of genuine B&O and have never had a single problem in all the years we've been selling them.
As beojeff mentioned though, nobody else makes the power cable which is B&O specific.
Lee
beojeff
USA
Posts 2,012
beojeff replied on Sun, Apr 9 2017 9:54 PM
9 LEE:
Lee
It's great to know that you offer those, Lee! If I ever need longer lengths for a wall installation, I'll be contacting you!
frog
Camberley UK
Posts 624
frog replied on Fri, Mar 30 2018 11:21 PM
I think the power cable is a 4Pin Kycon Power DIN Plug. I’ve ordered a couple of plugs from ebay to see. It’s unlikely that B&O invented a whole new socket/plug combo for their device, so I’m hopeful it will work. It only carries 12v, 5v, IR and 0V
Flyboy0229
Posts 10
Jeff;
May I trouble you for the manufacturers and part numbers of these cables, please?
V/r
Iverson
Flyboy0229
Posts 10
Jeff, I have a NIB B&O power cable:
* A18 Power Cable;
* 4.5m
* B&O PN: 6270905.
I paid $75 plus S&H. Yours for $80.00.
V/r
Iverson
beojeff
USA
Posts 2,012
beojeff replied on Sun, Apr 8 2018 5:11 PM
Flyboy0229:
* A18 Power Cable;
* 4.5m
* B&O PN: 6270905.
V/r
Iverson
This is not the appropriate forum for trying to sell items.
frog
Camberley UK
Posts 624
frog replied on Thu, Apr 19 2018 8:20 PM
The power plug is indeed a 4-pin DIN power cable. Note though you do need quite heavy cables as the current is quite high. I tried some standard 4-core, and they started to get a bit warm!.
Marcbe0
Netherlands
Posts 4
Marcbe0 replied on Tue, Sep 1 2020 6:38 PM
Hello  all,
I need to lengthen the power cable as well. Is 4x 0,50mm2 thick enough?
And the power connector, is that the sam as tis used for noteboks?
Thanks in advance for your reply.
Greating, Marc
marexy
Posts 710
marexy replied on Wed, Sep 2 2020 7:00 AM
If you are looking for non B&O sables ..please use all 3  shielded cables. Yes ..for power supply to !
I use 4x0,5mm2 it is enough ..black outside color..shielded cable with molex micro connector.
Hope that helps :)
Marcbe0
Netherlands
Posts 4
Marcbe0 replied on Wed, Sep 2 2020 8:29 AM
Hello Marexy,
that sure helps! Now searching for someone who sells that kind of cable.
Thanks.
Greetings,
Marc
Marcbe0
Netherlands
Posts 4
Marcbe0 replied on Wed, Sep 2 2020 8:30 AM
Hello Marexy,
Thanks.
Greetings,
Marc
marexy
Posts 710
marexy replied on Wed, Sep 2 2020 11:26 AM
You should buy cable as long as you wish..and soler molex connector on it.
that is it..
Page 1 of 1 (13 items) | RSS
DigiCert Secured Site Seal
