BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Eclipse 65V1-32Beosound M5Essence MK2BLI
Chris Hassell:Have you done anything interesting with it yet @seanie_230 ? I haven't had a proper play yet but I did a generic lights on/off switch.
Any good 'starter' macros or code samples available?
I'd love to have timed events happen, conditional on button presses or other device states...!
Carolpa:I tried to read the setting temperature of the Nest Thermostate and increase the value +1. Didn't succeed until now. I can adjust it to a value, but I want to make a button to increase / decrease the settings.
mjmedlo: Carolpa:I tried to read the setting temperature of the Nest Thermostate and increase the value +1. Didn't succeed until now. I can adjust it to a value, but I want to make a button to increase / decrease the settingsThis may be coming to you already in the next updates.
Still it is a good case to learn LUA
Hello,
I want to control lights brightness dependent with Lua, but it doesn’t work. I want to use my KNX-sonsor to set the mode setting dependent on the brightness. The outdoor sensor gives me a lux value displayed in the monitor. But I can not get it to read out the value so that if the value is above a certain lux value the mode is set to day (or light) and night (or dark). I tried it with Lua code but I cant get it work. I have to admit, that i am a total beginner
Here the code:
function(event, engine)
local result = engine.query("global/Terrasse/_KNX_Group_Address/Helligkeit")
if result[1].get("Value") > "30000"
then
engine.fire("global/Wohnung/VARIABLE/Tageszeit/SET?VALUE=Hell")
engine.fire("global/global/SYSTEM/BLGW/SET MODE?mode=Hell")
else
engine.fire("global/Wohnung/VARIABLE/Tageszeit/SET?VALUE=Dunkel")
engine.fire("global/global/SYSTEM/BLGW/SET MODE?mode=Dunkel")
end
I got this error:
18-05-01 11:58:59 Event fired global/Terrasse/_KNX_GROUP_ADDRESS/Helligkeit/SET?VALUE=26462
18-05-01 11:58:59 Event fired global/Terrasse/_KNX_GROUP_ADDRESS/Helligkeit/SET_NONZERO
18-05-01 11:58:59 Macro fired global/Wohnen/MACRO/Test Macro Helligkeit
18-05-01 11:58:59 Error: global/Wohnen/MACRO/Test Macro Helligkeit execution error: Line 3: attempt to index field '?' (a nil value)
Anyone here an idea what i did wrong?
Christof
