Beo5 and Beo6 using Sky+ HD - direct control
This post has 3 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sun, Mar 4 2012 12:42 PM
Does anyone do it? Does it work?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
malcolm welborn
canary islands
Posts 188
i have sky hd and use beo5 and beo4
Chris Harrison
Peak District
Posts 381
malcolm:
do you run it via a b&o tv or is a direct link instead of via PUC?
malcolm welborn
canary islands
Posts 188
I have a beovision 10 and sky hd digital box connected  im not technical bang and olufsen engineer set it up so surmise through sky box. using compatible sky commands with beo4/5 IR cable in front of sky hd box.
malcolm
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
