Since a few weeks it is no longer possible to use Spotify with BS5. It seems a software upgrade is necessary. I have checked the Beovision Avant and Spotify no longer works there either. Do you know about software updates from B&O?
Please use the search function of this forum before posting.
Spotify was removed from Beosound 5:
http://archivedforum2.beoworld.org/forums/t/25762.aspx
