hi all,
i just bought a beomaster 3300 to hook up to my beogram 9000. I am now wondering what the best solution would be to be able also to play music cordless from a telephone or computer. Any ideas?
all the best and thnx in advance
I bought a logitech bluetooth receiver and it works perfectly with my Beomaster 3500. Its the best and easiest solution. I did find that you need to use the 2 RCA connections on the receiver to get the best sound...the 1 RCA option on the receiver doesn't give as good quality.
Hi Comrades,
Welcome to Beoworld! If you use Apple phones, then Apple Airport Express will give better wireless range than bluetooth, or if you use Android phones then Google Chromecast Audio is a good alternative. For either of these devices, or a bluetooth receiver with a 3,5mm output socket, you can easily connect to the Tape socket of the Beomaster with this cable (you can also use this same cable to connect your phone or computer directly to the Beomaster if you wish):-
Standard cables (for the best value): http://soundsheavenly.com/bang-olufsen/67--trs-5pd-.html
High-end cables (for the best quality): http://soundsheavenly.com/music-systems/78-trs-5pd-super-.html
Please set the phone volume to maximum when connecting to the B&O system – this is normal when using a portable music player with a home audio system due to the low output levels produced by the phone.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
