I just lost my Beomaster 5500 and replaced it with a A?V 7000 without a remote. Will my remote from the 5500 work with the 7000. Additionally, the speaker connections are different. Does anyone know where I can buy an adapter so my speaker connections which worked with 5500 will now work with the AV 7000.
Not really the same thing! The AV7000 only has the centre channel amplified - the others are Powerlink and hence variable line level. The AV7000 is designed to work with a Beomaster rather than instead. The user and set up manuals are on site if you are a silver member.
Peter
