I played around with the new feature in the latest BLGW update that allows us to create macros to play specific Deezer playlists and TuneIn stations. It's actually very simple.
For the Command part of the macro, you select the zone (room), then the B&O multiroom product as the Resource. Then, for the Command, select "Playqueue add Deezer playlist." Tick the box for "Play now" if you want it moved up to the beginning of the playque. You enter the numeric ID in the box for "Deezer playlist Id." This numeric ID can be found at the end of the url when you select a playlist on the Deeer site in your web browser. That's it! Very easy and works perfectly.
beojeff:I played around with the new feature in the latest BLGW update that allows us to create macros to play specific Deezer playlists and TuneIn stations. It's actually very simple. For the Command part of the macro, you select the zone (room), then the B&O multiroom product as the Resource. Then, for the Command, select "Playqueue add Deezer playlist." Tick the box for "Play now" if you want it moved up to the beginning of the playque. You enter the numeric ID in the box for "Deezer playlist Id." This numeric ID can be found at the end of the url when you select a playlist on the Deeer site in your web browser. That's it! Very easy and works perfectly.
Hi Beojeff
Thanks for sharing this - works fine !
BR Rudi
