4002 turntable
ranitid
Posts 1
ranitid Posted: Wed, Sep 12 2012 12:06 AM
Is there someplace with a manual how to take cover off?  Have a problem with arm lifting off at end of play, but not high enough..therefor  runs on record  during first part of return..not very mechanical person, no local service. I need to adjust height of liftoff at end of record
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
This sounds like a lubrication problem. The arm is not lifting high enough fast enough!
If you slide the wooden surround forward about 1cm you will find that the aluminium panels will become loose and can be lifted out, starting at the rear right corner.
This article may help you:-
http://www.condoraudio.com/wp-content/uploads/Projects/BeoGram-4002-6000-Turntable-Restoration-Repair.pdf
Regards Graham
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Thu, Sep 13 2012 7:35 PM
Didn't Mika do a thread on this on the old site?
EDIT:  Yes, he did.  With pictures.  That survive.
Page 1 of 1 (3 items) | RSS
