About the huge list of reciver's on the MX-8000
Nic93
Is located in south denmark aabenraa/rødekro
Posts 50
Nic93 Posted: Mon, Aug 14 2017 2:05 AM
Its a really big shame that none of those tv boxes it supports are digital tv ready then it could be a nice alternate suqestion for digital television, and is it true you cant update that list or is it a another type of B&O tv you can update the list on?
Fritz
Posts 272
Fritz replied on Sat, Oct 14 2017 9:57 PM
Hi Nic. I am writng from Denmark. I have had the MX 8000, The reason that i changed it was the issue with the sat receiver digital receiver. It was fully prepared for this,but B&O in Stuer made another decision. However the European version has a build in Flash opgradeble STB-controller. I don't know if the NTSC (US version) has the same. If so, it can easily be upgradet using the STB upgrade Tool.
If your dealer has the laptop and the cable, pls inform with boxes you will need to be in the tables. The codes are downloaded from the net, About 22 to 40 boxes can be in the table. If the TV has the three RGB rca plugs you can use the lowest HD resolution using these plugs. And control the receiver fully by using Beo 4.
brgds/fritz
Page 1 of 1 (2 items) | RSS
