Anyone tell me if the tonearm is used on other models?
Not in its entirity.Some parts are common with Beogram 1200, 1202, 1203 and Beocenter 3500.
Thanks Martin. Trying to work out what someone means when they say the arm is loose. I think its a case of bight the bullet. Are they easy to repair? i repair cameras so have some ability.
Easy to repair?...Well, that depends on your skills, I suppose but they are not the worst ones.
Thanks.
"Lose" could suggest one or more missing steel balls in the antiskating mech.
Jacques
