tx2 tone arm and platter stuck
This post has 11 Replies | 8 Followers
jtaylor78
Posts 1
jtaylor78 Posted: Thu, Sep 20 2012 4:41 AM
I purchased a TX2 in working condition, but after less than 20 minutes of use it has frozen.  It was playing fine and I pressed the "stop" button.  The tone arm lifted and began to move to the side, but it then stopped.  The platter stopped too.  Both are immovable. I can hear the motor humming but it is not spinning. I have tried pressing the buttons, turning it on and off, etc.  Nothing works.  The platter will not rotate in either direction (unless I lift it up using the 45 adapter...but if I sit it back down it will not rotate).
Any ideas?
Søren Mexico
Mexico City
Posts 6,411
Open it up and take a look at the big cam gear it must be blocked by something, the cam gear moves the arm, and is moved by the platter shaft gear.
Edit: Sorry I read RX2, do as Martin tells youIck!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Sep 20 2012 7:00 AM
Push the tonearm carriage all the way to the right by hand and take off the record.
Lift off the platter and check the platter belt.
Kevin
California, USA
Posts 1
Kevin replied on Sat, Apr 23 2016 7:39 PM
I have this exact same problem.  I am an original owner, and the TX2 has always worked flawlessly, but after an extended dormant period it jammed just as described during the automatic return at the end of an LP.  The start/stop gear mechanism is locked up in the middle of the return cycle such that the platter and the sliding chassis will not move in either direction (both belts are okay).  I can remove the start/stop cam lifting wheel and put everything back together the way it's supposed to be, and it will perform all operations correctly except for the automatic return at the end of an LP which will jam again at the same place.  This seems like such a specific problem that I was hoping someone would point to a particular broken spring or pin that would cause this symptom.  There is a cavity in the bottom of the cam lifting wheel that I think is for the pin on the record sensing arm, and the tracks in the grease suggest that maybe this pin is coming out of the cavity.  Is that possible?  Would that explain this jam?  How would you fix it?
Any suggestions (even just sympathy) would be appreciated.
tztag
Posts 9
tztag replied on Mon, Jan 22 2018 4:52 PM
Mine did the same.  You can remove the circlip and get the arm pulley moving again if you lift it slightly.  I'm guessing that the worm drive belt is slipping.  Anyone know what size belt it takes?
Dillen
Posts 13,191
Dillen replied on Mon, Jan 22 2018 9:47 PM
It's probably that well-known small arm under the rear cam wheel, that blocks the wheel when it gets distorted.
I can supply correct belts, both the platter belt and the triangular belt for the tracking motor.
tztag
Posts 9
tztag replied on Tue, Jan 23 2018 7:11 AM
Thank you! Yes I would like to buy the belts from you- please let me know next steps. Would like two sets.  Where can I read about the arm issue so I can fix?  Really appreciate the help
Dillen
Posts 13,191
Dillen replied on Tue, Jan 23 2018 11:51 AM
The arm issue was discussed here not a long time ago.
PM me for belts info.
Dustmaker57
Posts 9
I am a new owner of a TX2, and I have the same issue described here.  The platter just locks when I press stop while the motor continues to turn.
i know this thread is old but I looked for the small arm issue you mention above and find the discussion.  Can someone advise me on how to adjust this?  I took all the gears off, ensured they are properly lubricated.  I then reinstalled all gears attempting to ensure all are properly seated and engaged.  I still have the same issue.
im stumped
Dustmaker57
Posts 9
I meant to say, “can’t find the discussion”
Dustmaker57
Posts 9
Never mind.  It started working and the platter no longer locks.  On to the other issues
Dustmaker57
Posts 9
Page 1 of 1 (12 items) | RSS
