Hi anyone know for sure if record deck motors from those 2 are inter changeable?
Appreciate it
(being browsing through my manuals, but haven't got 1202 only 1200
thanks for reply
bob
Don't worry - be Happy
BG 1202 and BG 3000 the motor has the same part number
Søren Mexico: BG 1202 and BG 3000 the motor has the same part number
Guess it must be the same in the BeoCenter 3500 Bob is referring to...
Thank you both of you guys (don't know how to multi quote)
according to service manuals of the products you right 1202 and 3000 are identical, where on the othe end BC3500 has different part number
I've to bother Dillen if it's doable and worth in first place (it appears bit of work would be required)
All the best
The Beocenter 3500 motor is probably a 110-120V type to allow for voltage switching of the BeocenterBest check this before eventually swapping.
Thank you, from what I've seen in service manuals of 1202,3000 and bc3500 it may be more than that ;), if nothing they're different part Numbers
Dillen: The Beocenter 3500 motor is probably a 110-120V type to allow for voltage switching of the BeocenterBest check this before eventually swapping. Martin
There are other differences, that's right.The placement and type of speed fine adjustment is different too.
