Hi Guys,
Just acquired a beocenter 4600, lovely bit of kit, but there is no auto return on the turn table and no output from the cassette. The cassette i'm not to bothered about at the moment. Upon lifting out the turntable I found these items... I looked up the manual and they are springs for the clutch? and the toothed belt was hanging from the switch assembly.
Could anyone send me an image of how they are supposed to fit and if the belt is available and what it does?
Thanks Gary
Hi I have a beocenter 4600 that I don't want it does not work but might be useful for you as parts I live in Southampton and you are welcome to have it for free.
Would you believe im actually coming through to Southampton tomorrow. Would love a unit for spares... message me your address
Dunno about the springs, but that toothed belt is just for the speed adjustment dial. The turntable will work without it.
This music centre has a great sounding amplifier, and the turntable isn’t bad either. Well worth restoring and using - good luck!
--mika
You have a PM/email with address etc.
