Beolab 5 Best CD Source
j0hnbarker
Posts 187
j0hnbarker Posted: Fri, Sep 29 2017 7:42 PM
Evening all,
So I've moved with the times and am getting some Beolab 5s.
What I need to decide now is what source to connect.
I had planned on a Beosound 3200 but hadn't realised it didn't have an optical out.
Is it best with these speakers to use a deck such as the Beosound 9000 with an optical out and let the internal DAC in the Lab 5s handle the processing, or should I get the 3200 and use the DAC in the 3200 and connect via Powerlink to the speakers.
Will there be a notable difference in sound quality either way?
I should probably add that I want to use the Lab 5s in the same room as a BS3 connected to a BV4 and BL10.
CB
> You are Here <
Posts 1,762
CB replied on Fri, Sep 29 2017 10:57 PM
Congratulations jOhn Beer
The BL5s don't have an optical connexion, it's coaxial. And yes, the sound will be better through a digital connexion. A BS9000 (as any BeoSound with a digital output) may be a good choice. It has the needed coaxial and Powerlink outputs for the BL5s.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Sep 30 2017 1:22 PM
The best sounding CD source I had connected (digitally!) to my BL5s, was a BG CD7000. I`d get a Beomaster 7000 and a BG CD7000 (they are cheap nowadays...), connected to a BL 1611 converter and to your BS3. Connect the digital output of the CD7000 directly to the BL5 digital input.
If you press CD, the BS7000 and the BS3 will start and activate your BL5s in audiomode - SPEAKER2. Source detection and volume level control will work via Powerlink through your BS3, audio signal will work directly from CD7000.
Stefan
j0hnbarker
Posts 187
Thanks Both!
In the interim I have gone and bought a BS9000 from a second-life dealer.
I had thought about one of the Beosystem 6500 or 7000s and using the digital out from the deck, but I think in the space I have the BS9000 will fit better.
Now I just need to work out how to connect everything up...
I have various new pieces coming, and will have the following:
Living Room
Beosound 9000
Beolab 5s
Beosystem 3
Beovision 4
Beolab 10
Bedroom
Beovision Avant CRT
I want to ML the BS3 and BV Avant together so that I can watch Sky in the Bedroom.
What I was thinking cable-wise was I'd need:
ML cable to connect the Avant and the BS3 together
SPDIF cable out from the BS 9000 to one of the Lab 5s. Would I then need another one to run between the two Lab 5s?
Powerlink 8/8 x2 so that the speakers know when to turn on.
Then I'm stuck! How would I connect the speakers to the BS3 so that I can listen to the TV through them?
alee
Posts 52
alee replied on Sun, Oct 1 2017 10:02 PM
I’ve been playing with a non-B&O CD player. If you want to be able to stream audio to the BL5s, decode MQAs, FLACs and use a coax connection, the NAD M50.2 is a really nice piece of kit. I managed to get one for just under $2500.
Sweden
Posts 357
Silver Member
Martin replied on Mon, Oct 2 2017 3:49 PM
Best digital feed to Labs5 is using a Auralic Aries network streamer. I have tried many other (cheaper) streamers and very good CD-players to the lab5 and the Auralic Aries streamer is the best on the market. There is no DAC inbuilt this streamer and you must use the coaxial digital feed to labs 5.
If You want more information and test-results from Auralic, just read all the reviews on the web.
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
stefan
Posts 2,920
stefan replied on Tue, Oct 3 2017 11:40 AM
- Congratulations!
Living Room
Beosound 9000
Beolab 5s
Beosystem 3
Beovision 4
Beolab 10
Bedroom
Beovision Avant CRT
- Your BS9000 should also be masterlinked to the system, and connect the BL5s to BS3 - Powerlink front L/R.
- Yes.
- These should come from BS3.
- Your BL5s are connected to BS3, so you can listen to video- AND audio soureces through BL5s. BS9000 (audiomaster) must be in A.OPT 0 (usually will be set automatically, when no Beolabs connected) - BS3 (videomaster) must be in V.OPT 2. I`d set SPEAKER mode to 1 or 3 for video, and mode 2 for audio, so if you select RADIO, A.AUX or CD BL5s only will turn on. If BL5s detect CD mode, they will switch to digital input. In this case, source selection and volume level control will still work via Powerlink. Set your Avant to V.OPT 6 (link BV). Now you can control all audio´and video sources connected in the mainroom. For video distribution you will need an antenna cable and maybe an RF link amplifier.  Your stb in the mainroom must be capable to transmit picture and sound simultaneously via HDMI and SCART (composite). Picture quality in the link room will be standard definition.
Stefan
Page 1 of 1 (7 items) | RSS
