Hi - I bought an old beogram 2404, but the lid would open proporly and hold it self open. Therefore, I unscrewed the lid hoping i could fix it. However, i can se that the plastic itself is broken, so Im not sure i can find a way to resolve the problem.
Now the problem is, that i want to use the turntable as it is (everything else works perfectly) but i cannot figure out how to reattach the lid. Specifically, each side has a small metal arm that is meant to hold the lid when open. How are they suppose to be mounted? I really cant figure out.
Stupid, I know. Im not experienced and simply wanted to play around with it, so if anyone can help im very grateful!
*but the lid would NOT open proporly
