Pairing Beoplay A1 with bluetooth transmitter
This post has 2 Replies | 2 Followers
Gordon Venters
Auchterarder, Scotland
Posts 7
Silver Member
Gordon Venters Posted: Sun, Nov 12 2017 12:55 PM
Has anyone had success pairing A1 to a bluetooth transmitter?
I am trying to use a bluetooth transmitter (Taotronics TT-BA10) to link the aux socket from Beomaster 1700 to my Beoplay A1 via bluetooth.
I have switched off all other bluetooth sources and tried clearing the pairing memory on both the transmitter and the A1 and then putting both in pairing mode but they will not pair. I need to do this just using the switch controls on each device since the transmitter will not be recognised by the Beoplay app.
I'd be very grateful for any advice please.
Gordon
Gordon Venters
Posts 7
Silver Member
Update: Problem solved and the Beoplay A1 now pairs with the transmitter. I had failed to clear the pairing memory properly on the transmitter - this requires the usb charger to be connected while the power button is pressed for 3 secs. After that, with both transmitter and Beoplay A1 reset to factory settings, the devices paired first time. I then successfully paired iPhone and iPad with the Beoplay so everything works now.
This inexpensive transmitter is pretty good - decent quality and range. This is the 20m range version.
Hope this might help others.
TWG
Posts 1,672
TWG replied on Mon, Nov 13 2017 10:14 AM
Welcome to Beoworld! :)
Thank you and yes, it is a helpful hint!
Page 1 of 1 (3 items) | RSS
