I have a BeoSound 5 - BeoMaster 5 setup. Recently downloaded the new OS High Sierra software on my Mac. Since then, I have been unable to connect with the BeoMaster 5 on the network. Useing the “Command-K” keystroke I can get to the window that asked for the password to connect. After entering the usual password that has always worked, I receive the error message that it was “Unable to Connect.” Has anyone experienced this same problem since downloading the new OS software? Is there a fix, not sure what to do?
