Hello Beoworlders,
It's friday and also housemaid's day.
Since this charming lady is a bit dangerous for fragile items, I use to cover my B&O stuff and store my remotes and Moment's jukebox in a drawer.
Unfortunately, I do not know how to turn-off the jukebox and find it with a drained battery on friday evening.
May you help me?
Have a nice week-end,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Hold the "play" button for some seconds
But it easily turns on again, so put it were it should be stored and place it in stdby
Thank you for the tip.
That's what I do, but the JB is placed in standby and not switched off.
So the battery drains and when I place it on the Soudheart it reboots (B&O logo is displayed).
Kind regards,
YannChris: Hi, Thank you for the tip. That's what I do, but the JB is placed in standby and not switched off. So the battery drains and when I place it on the Soudheart it reboots (B&O logo is displayed). Kind regards, Yann.
You can turn off the jukebox by using a paperclip in the small hole besides the charging pads. It is also the on used to reset the jukebox. I cannot remember exactly how many seconds it needs to be pressed in before it shuts down. Something tells me about 2 seconds, then it should turn off, maybe less :)
To get it back to life, I think it is just a push with the paperclip again.
Its been a while since I did it, but it is possible :)
/Jacob
I am short of paperclips.Would the toothpick do the job ?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Suggesting to dealers: pls include paperclips/toothpicks with standard accesories.
