Ca anyone tell me how to find the serial number of a avant 55 via the remote control ?
i cannot find anything in the manual or via a web search
i suggest to go for the BeoTool-app, starting a report there while TV is switched on
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
ajvc: Ca anyone tell me how to find the serial number of a avant 55 via the remote control ? i cannot find anything in the manual or via a web search
I think if you go to set up, then 'red' - 'go' will take you to customer service menu, and it will probably be there? I can check tomorrow if not. Is it a new generation?
