Hi Everyone,
I have a new in box table stand to suit the AVANT 75 or 85'' TV. Both the MK1 and NG versions are compatible with this stand. It was removed from the box for one day and then put back in the box (long story). I no longer require this stand. This is the STB bracket item - so excellent build quality and specifically designed to fit the AVANT. Note - you'll need a strong TV cabinet/table to support the stand and TV together, they are HEAVY!
I paid normal retail for this (1390 GBP). Make me a reasonable offer and I'll let it go. My loss is someone else's gain.
If the offer is good enough I'll freight it free, anywhere.
Item currently located in Dubai, UAE.
Thanks, Dave
