I am thinking about buying an Beosound 1 to have an extra speaker I can place wirelessly in the room. Will the beosound 1 be able to be linked to the Avant and play music without delay (seeing that they will be placed in the same room)? I do not really care about video sources for the Avant, just music!
Thank you in advance!
Yes, if you are playing Deezer on the TV, the BeoSound 1 will be able to join without delayed sound.
Thank you! Also other audio sources?
Beosince98:Thank you! Also other audio sources?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Please see section for the BV Eclipse here:
https://bogo.custhelp.com/ci/fattach/get/1304261/0/filename/Multiroom+-+october+2017+-+PDF+handout.pdf
Have a look here:
Please forget my first post - as the question was about the Avant!
Beosince98:I am thinking about buying an Beosound 1 to have an extra speaker I can place wirelessly in the room. Will the beosound 1 be able to be linked to the Avant and play music without delay (seeing that they will be placed in the same room)? I do not really care about video sources for the Avant, just music! Thank you in advance!
Thank you very much for your reply!
I would say that it depends on how you set the delay and how sensitive you are. I have a living room and a kitchen that are basically one room, with a complete Avant setup in the living room part and a BS2 in the kitchen part - and the delay makes me seasick, while no one else in the family takes notice. The room is fairly large, though (140 m2).
Roger
