Hi all,
I've recently upgraded from the "Beolink" app to the "Beolink 2" app to control my masterlink network via a MLGW. I really like the look of the newer app.
Everything is working as expected, but I'm wondering if it is possible to set up zones to group rooms with the MLGW, or is that option only available to owners of the BLGW? At the moment all of my rooms appear under the "MAIN" zone, but ideally I'd like 3 zones (Upstairs, Downstairs and Outdoor).
Thanks for any advice
Luke
have you solved the prob already?
You can build up seperate rooms under "Programming" "devizes". When you then create your virtual buttons, you can choose a location for them, according to your previously created rooms.
BR
Niels
