Renewing Beovox C40 speakers. New drivers? New capacitors?
This post has 1 Reply | 2 Followers
roadie
Posts 1
roadie Posted: Tue, Dec 26 2017 5:49 PM
Hi all and Merry Christmas,
My parents have owned a B&O system for as long as I can remember (over 30 years).  This currently consists of a BeoCenter 7007 connected to a pair of Beovox S45 speakers (the 2 way version).  It also used to power a pair of Beovox C40 speakers in a different room, although these have been unused for some time following renovation.
I thought I might take the C40 speakers on to use with a SMSL SA-36A Pro amp.  However, they are in need of some TLC.  The foam around the woofers is shot and I am wonderinghow extensive any refurbishment should be.  Should I simply refoam the speakers?  Could brand new drivers be used?  Given the age of the speakers, might the capacitors need replacing too?
I have taken the speakers apart and found that the bass driver is labled "8480143 Japan 331TNG".  There is also a single bipolar Elko Rauh 15MFD63v capacitor present.  Can anyone recommend replacements?
Any help would be greatly appreciated, as I have good memories associated with the speakers and would like to hear them at their best.
Thank you
Menahem Yachad
Jerusalem, Israel
Posts 1,249
There are many professional speaker reconers who will install new foam.
I have been using Solen capacitors for many years in my speaker restorations.
Specifically this 400V PB series. You'd need a PB1500 model for your 15uF cap.
Page 1 of 1 (2 items) | RSS
